OEM cargo divider- two questions
greenlawnracing
I found one on marketplace, and it is missing the key. Has anyone ever had like simply getting one made at the locksmith? Is there something elusive about this key?
I do not have ramboxes, but I like this divider because it is a bed extender that it’s easy to store. Will it fit with non-ram box trucks?
dts828
Atlanta, GA
Sorry can only be used in ram box models.
The lock cylinder should be able to be rekeyed. The cylinder can be be removed by removing hex set screw on side of handle then pulling the cylinder straight out.
mikeru82
The Palouse
No, you can't use this with the non-rambox bed. Which makes the key issue moot.
greenlawnracing
Welp that sucks! Seems like it’s the closest thing you’ll get to Ford’s folding bed extender.
am I safe to assume that it will not fit as a bed extender either? I understand that you can’t use it as a divider, but I’d still get it if I could use it as a compact bed extender.
mikeru82
The Palouse
Sorry, it won't work for that either.
