c3k
- Jul 22, 2020
Folks,
I'm researching some accessories.
- Banks PedalMonster uses an OBDII plug
- Amp-Research PowerStep Running Boards ALSO uses an OBDII plug
It's obvious why each of the above uses the OBDII port.
Is there any OBDII Y junction? Meaning, any way you can have BOTH of the above items accessing the OBDII port at the same time?
Nevermind. Found the Pass Through harness.
Leaving this here in case anyone else has the same question.
