Motoryan716
- Dec 11, 2021
Does anyone know why Ram won't build Bighorn models with Ramboxes. I tried to order a Backcountry model and my dealer said the ordering system doesn't give that as an option.
It's because of money really. Those lower trims that having more fancy options like that are being pushed down, are not a priority or not making those parts available.Does anyone know why Ram won't build Bighorn models with Ramboxes. I tried to order a Backcountry model and my dealer said the ordering system doesn't give that as an option.
You can only get the rambox option on short beds (5'7"). Were you ordering a truck with the longer bed? I'm seeing the rambox option as available on the Bighorn on the ramtrucks.com website, if I select the crew cab with the short bed.Does anyone know why Ram won't build Bighorn models with Ramboxes. I tried to order a Backcountry model and my dealer said the ordering system doesn't give that as an option.
Appreciate the explanation, but I'm aware of the issues with the ramtrucks.com website. The only models I've heard that you can't get ramboxes for is the Tradesman. The OP only said which model he was trying to order, but said nothing about which bed he was including. He also included Longhorn models in this thread title, and I know you can definitely get the rambox option on a Longhorn. The OP may not be aware that the ramboxes can only be ordered for the short bed.Here is the thing…just because you can build it online using the comfigurator, doesn’t mean it’s available when you try to order it at the dealer. We saw this early on with us folks when ordering. We have seen changes, due to the chip and product shortages.
Also, by any chance if you can order it, it won’t be built right away. Higher trims with higher price tag will most likely take priority, over lower trims and the extra we add.
2021 Ram Rebel
2016 Dodge Charger scat pack
2021 Jeep Wrangler Unlimited Sahara (wife)
Corrected your thread title. Lonestar, not Longhorn.Does anyone know why Ram won't build Bighorn models with Ramboxes. I tried to order a Backcountry model and my dealer said the ordering system doesn't give that as an option.
Yeah I know it's available on the truck builder 5'7" beds and in says it's available on the Bighorn models and when you look at the pictures of the Backcountry, it has them but you can't order them. I just talked to a 2nd dealer, same dealYou can only get the rambox option on short beds (5'7"). Were you ordering a truck with the longer bed? I'm seeing the rambox option as available on the Bighorn on the ramtrucks.com website, if I select the crew cab with the short bed.
ThanksCorrected your thread title. Lonestar, not Longhorn.
I know they do that but press releases said no Ramboxes or Multifunction tailgate on the Tradesman but the boxes were s available on the Bighorns. Even the website states it's an option.Because not every option is available for lower trim levels. Otherwise a lot of people would never order higher levels. Of course, they keep adding more and more options to the BH every year it seems.
