I was looking at the service intervals for my Eco Diesel and it says transmission fluid should last the trucks life without changing. I've always change the filter and fluid every 75,000 miles on past trucks. I do have a 5 year 200,000 mile Max Care extended warranty. If I the trans makes it that long without failing, I'd be worried changing the fluid & filter at that time (always been told if you don't change it before 125,000 miles leave it be, as you run the risk of loosing up crud that has built up in the case) Any transmission specialists out there that have an opinion?
