Nitto tires true to size?
ronasmithii
I got a set of Nitto Recon 285/60r20s installed today. calculated they'd be 33.5 tall. Got home and I noticed that on the vehicle they measure up to ~32.5. About an inch off.....is this normal? Does an empty bed on a 1500 have that much compression?
Love the tires either way but curious
H2OMAN
The O.C.
265/50R20 111T XL21882013.430.4710.917.5-(8.5)-9.52403 @ 5040.10
LT265/60R20 E 121/118S21855015.732.5210.718.0-(8.0)-9.53195 @ 8054.01
275/55R20 117T XL21801013.531.8911.187.5-(8.5)-9.52833 @ 5044.31
LT275/55R20 E 120/117S21826015.931.8911.188.0-(8.5)-9.53085 @ 8053.76
275/60R20 116S XL21838013.532.9910.987.5-(8.0)-9.52756 @ 5046.98
LT275/60R20 E 123/120S21830015.932.9910.988.0-(8.0)-9.53415 @ 8055.03
275/65R20 116T21846013.534.0910.987.5-(8.0)-9.52756 @ 4447.53
LT275/65R20 E 126/123S21800015.934.0910.988.0-(8.0)-9.53750 @ 8058.60
285/50R20 116T XL21843013.631.2611.698.0-(9.0)-10.02756 @ 5044.86
285/55R20 116T XL21883013.632.3611.698.0-(9.0)-10.02756 @ 5047.00
LT285/55R20 E 122/119S21823016.032.3611.698.5-(9.0)-10.03305 @ 8056.66
LT285/60R20 E 125/122S21831016.033.4611.508.5-(8.5)-10.03640 @ 8059.88
LT285/65R20 E 127/124S21818016.034.5711.508.5-(8.5)-10.03860 @ 8060.30
LT295/55R20 E 123/120S21819016.132.7612.178.5-(9.5)-10.53415 @ 8060.07
LT295/60R20 E 126/123S21817016.133.9411.778.0-(8.5)-10.03750 @ 8060.53
LT295/65R20 E 129/126S21821016.135.1211.778.5-(8.5)-10.54080 @ 8064.93
305/50R20 120S XL21842013.932.0512.448.5-(9.5)-11.03086 @ 5049.98
305/55R20 116S21840013.933.2312.448.5-(9.5)-11.02756 @ 4451.37
LT305/55R20 F 125/122S21825016.333.2312.449.0-(9.5)-11.03640 @ 8065.79
315/60R20 116S21836014.034.8812.728.5-(9.5)-11.02756 @ 4457.23
LT315/60R20 E 125/122S21832016.334.8812.729.5-(9.5)-11.03640 @ 6569.84
LT325/60R20 E 126/123S21822016.435.3513.039.5-(9.5)-11.53750 @ 6571.10
34x11.50R20LT E 121R21833016.933.5011.428.0-(9.0)-10.53195 @ 8061.88
35x11.50R20LT E 124R21809016.934.5311.428.0-(9.0)-10.53525 @ 8060.65
33x12.50R20LT F 119R21805016.932.5212.528.5-(10.0)-11.03000 @ 8062.68
35x12.50R20LT F 125R21802016.934.5312.528.5-(10.0)-11.03640 @ 8070.35
37x12.50R20LT E 126R21803016.936.5412.528.5-(10.0)-11.03750 @ 6574.30
35x13.50R20LT F 126R21811016.934.5313.589.5-(11.0)-12.03750 @ 8076.08
37x13.50R20LT E 127R21807016.936.5413.589.5-(11.0)-12.03860 @ 6579.19
Technical specs are subject to change without notice. LT tires with a "C" load range have a 6-ply rating. LT tires with a "D" load range have an 8-ply
O'Town Ram
I know less and less about more and more
Orlando, FL
What pressure are they at. I wonder if the 33.5 is at 80psi
jgdblue
I noticed the same thing on my Recon Grapplers, 275/60R20 XL should be 32.99. They actually measure 32.25 at 40 PSI (Max PSI is 50).
It doesn't really bother me for some reason, I really like the tires.
