Malcolm745
- Dec 14, 2023
New Uconnect firmware just rolled in 31.42 . Haven't had a chance to install yet. I'll get to it tonight. Hoping for full screen Android Auto finally...
Any other impressions, good or bad? Got some things on the UC5 retrofit in my 2019 2500 that aren't working with my 12" cluster retrofit. Wondering if a software update will help.Just updated my 2022 limited but as you said no full screen AA...
Haven't had all that much time with the truck since the update. But from what I've noticed the navigation volume is saved after I start the truck the next day. Normally I was blasted with some default setting each time. Rear cam park lines have a center line now (didn't have this in 27.46 ) . Apart from that haven't noticed anything.Any other impressions, good or bad? Got some things on the UC5 retrofit in my 2019 2500 that aren't working with my 12" cluster retrofit. Wondering if a software update will help.
For the rear cam do you mean the dotted line in the center? I have had that in mine for as long as I can remember. I switched the display from assisted with curved lines to straight lines and it's always been there. I have 27.46 installed, but it was there for several previous versions. I'm that guy who drives to far end of the parking lot away from everyone else, and backs in between two spots and I puts the dotted line on the yellow painted line as I back in.Haven't had all that much time with the truck since the update. But from what I've noticed the navigation volume is saved after I start the truck the next day. Normally I was blasted with some default setting each time. Rear cam park lines have a center line now (didn't have this in 27.46 ) . Apart from that haven't noticed anything.
I’ve seen this before, and it’s probably a radio module that was used for testing. I doubt your radio will take a production update, but you can try. This is the latest:Does anyone have the latest software for the UConnect 12 screen? I did this upgrade on my 2024 tradesmen 2500 and am needing to update the firmware, but UConnect website says it's up to date. wanted to see if anyone would happen to have the update that I could download? the android auto has a watermark (pre-production hardware not for sale). really hoping a software update would fix my issue. my current build number is fca-my23.t25.43
the head unit came off a 2023 ram 2500
does it have to be a 16 gig? I only have a 32 gig.I’ve seen this before, and it’s probably a radio module that was used for testing. I doubt your radio will take a production update, but you can try. This is the latest:
16gb USB stick format to fat32. Do not unzip or extract anything, just put the whole zipped folder onto the usb stick and plug it in.UCONNECT_R1HIGH_T27.46_MY22-23DT_MY22-24HDCC.zip
drive.google.com
My guess is it’s going to say software not compatible with vehicle.
You were correct it did not take! Is the screen good I just need a new nav module uconnect 5?I’ve seen this before, and it’s probably a radio module that was used for testing. I doubt your radio will take a production update, but you can try. This is the latest:
drive.google.com
That’s what i figured. Screen is fine, you just need another radio module.You were correct it did not take! Is the screen good I just need a new nav module uconnect 5?
