New timbergrove airbag gauge issue
LITTLEREBEL
South Louisiana
I installed my timber grove rear air bags on my 19 Rebel and the pressure gauge isn't reading the pressure. The sensor connects to a shrader valve on a air pump and is supposed to read how much pressure is in the bags, but it wont show me a number. I also looked the gauge up and its used for valve stem tire pressure. Is there another gauge that I can try?
Rick3478
NW OH
There's a lot of variation in Shraeder valves. Sometimes the release pin is recessed so far you can barely get air in, and if the sensor doesn't happen to depress the pin far enough, it won't work. If the sensor is going to be permanently installed on a pump, you don't really need the valve core, so you could remove it and screw the sensor back on the open stem. Or try a different valve core, there are different designs that vary in quality.
