New LED style CMHSL - strobing issue
That's -exactly- the type of output I'm looking to get from my CHMSL as well. A rapid flash or strobe effect for just 1 second - then on solid until I stop braking. Strictly for a "Heads up! I'm braking!" alert.
Ya works great. I don't remember the settings I think slow and six in the Tazer but it's real quick flashes then solid I love it.
i have mine set for slow flash and 10 flashes.. I personally love it. Also love the light mode when *******s are in front of you being dumb. It does scare the bajesus out of them, and usually get out of your way. NO I don't suggest doing this... Off road purpose only.. you know.. lol
Yep I think mine is slow and six,works great. what iight mode are you talking about the fog drop ? We just need to get all the dumb people off the road.
LOL... agreed... I'm dead sick of this new movement of driving 60mph in the passing lane.
So in the tazer you have an option called light show... You can program this by plugging into your computer and setting how you want them to light up. 2 special menus to make your own... or use the 6 pre-programmed modes. If you have the full led lighting its SO much fun. Work with the base lighting too... I started with halogen lights, then upgraded to factory-led, and factory-led tails. Check it out, let me know what you think.
Ok you are talking about the light show. I have used the six pre-programmed before,they are cool I have my Tazer in the truck all the time but not married and the light show dosn't work with the fob. Z automotive said it does but mine wont work with it unmarried.
Hmmm.. so I connected my bypass cable and plugged in my Obdlink-MX and fired up AlfaOBD on my phone. I saved a copy of my BCM to my phone and emailed it to myself. I renamed the file to "Body_Chyrsler...Factory_Configuration.txt" and saved it to my PC and Google Drive. I see there is a setting for "LED CHMSL Lamp Present" that is currently set to "No". Has anyone played with this setting and if so, was there more to change to keep the related error code from being set? Thanks
Yes… if you change to LED bulbs you can change that setting. It does change the pulse width modulation. Same time if you are getting error reports due to lights being out, and setting check engine light, you can turn that feature off as well.
Yes light show. It does work from my remote. But I find works best with ash hole drivers lol. Again read my disclaimer above. I don’t condone breaking any laws. But you do need the unit married to your vehicle. Then you will find a slew of other items that you can access and change. Also… having your SwG disconnected is not going to hurt anything. Fact, if you worried about folks being able to take over your truck, this will take that ability out of circuit.
Why do you not leave this installed and married? I’m curious.
I used to have it married all the time, I guess I just got last most of the stuff I use is live settings, Pin-Lock, Eng Start-Stop, AMBER DRL'S maybe I will marry it again.
Supposed to have been Lazy.
