SD Rebel
I just picked up my Ram 1500 Laramie 4WD offroad edition with 3.92 rear axle. The EPA rating on the window sticker says 17 MPG city, 21 MPG highway, 19 MPG combined, but I'm getting about 12 MPG in the city and averaging about 15 MPG on highway. I am REALLY taking it easy on the driving and it shows it to be in ECO mode most of the time. I have zero additional mods on the vehicle. I didn't buy the truck for MPG, but I was expecting to perform relatively close to the ratings. This truck is performing almost 30% lower. My questions are:
1. Is the EPA rating on the window sticker based on the truck configuration or based on some base trim with none of my options? If it's based on some arbitrary configuration, then it is really misleading.
2. Do the HEMIs have a large break-in period before efficiency climbs back to normal range? My current mileage is only around 100 miles or so.
3. Does the higher octane fuel (89) that's required by the manual make a noticeable difference? I'm still driving on the full tank that the dealer provided and I'm not sure what they put in there. I am guessing that they used regular gas, but in my experience higher compression engines perform the same on lower octane fuel as long as there is no heavy knocking and I haven't heard anything while driving around.
1. The EPA rating is based on a similar configuration RAM (i.e. crewcab 4x4 w/ short bed), using 18" street tires and likely a 3.21 rear axle. Then RAM blanket states all variants, including OFP and Rebels with 3.92 and 33" tires. They aren't going to come close to the EPA rating.
This is a common complaint of how RAM does their EPA window stickers. It's been brought up by TFL truck for example on their Rebel. You are allowed exceptions to lower mpg based on variants, like GM does with the Trail Boss. But RAM decided not to do that, which I think is a bit shady by them.
2. Hemis break-in, but not close to enough for your truck to get in the window of the EPA rating.
3. Yes, for the best performance and mpg, you should use 89 octane.
However, you can kinda get close to the EPA rating is you drive really easy. I mean like an old person who isn't afraid of pissing off all the driver's behind them. If you drive like that, including the slow lane on the freeway, you can get surprising good mpg.
If I drive my Rebel like normal, I get 13 mpg, if I hypermile it, I can get 18 mpg combined, but it's zero fun that way. The other option is to get small all-season road specific tires, you will see a nice jump in mpg as well.
