34s are probably fine if you don’t have mud flaps. I have less than a 1/2 inch clearance on turns with my 33s. You could do surgery on the flaps to make it work. I’ll be going this route when I get more miles on my current tires
I have -12 offset wheels and the Wildpeak 295/70 34s and had to trim the inside portion of the stock mud flaps. I have the bilstein 6112's at the highest setting which is about 2.6" taller than stock. You can't tell the flaps are trimmed unless you stick your head in the wheel well and look for it.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
