Choate
- Sep 8, 2021
Guys I’m dead set on this size but I’m struggling with what to choose. I very rarely go off road and don’t tow but I definitely want an AT tire. The only one in this size non E rated is the nitto terra grappler g2. I had this tire that came on my previous truck and they were worn down probably 3/4 of the way and totally sucked in the rain when trying to take off. You had to barely and I mean barely give it gas. Otherwise seemed ok. I’m considering the toyo AT3 as well but they’re quite a bit more $ and E rated but not all that much heavier. I absolutely love my Wildpeaks but in this size they’re extremely heavy. 67lbs I think. Read the BFG are bad in rain too so I guess what I’m wondering is would you go w the nitto g2 SL tires and air up and are they ok in rain when new or buckle up and pay for the toyo and are they good in rain? I live in DFW TX so snow is not a consideration in tire selection. Thanks for any advice. The reason for changing tires is I’m about to add the RC 3.5” lift and my 33s will probably look too small. I know an inch isn’t much but I don’t want to go up to 35” since I have the 3.21 gears.
