Need Help - Tazer DT
Standers
Today while driving my dash starts to completely “spaz out”. It’s turning off the center console, saying my blind spot monitor no longer works, windows aren’t rolling down, turn signal light is out, etc.
The screen keeps flickering and I have no control of the functionality. I have a Tazer DT installed and I suspect that’s what is causing the issues. I’d like to unmarry the unit and unplug, but I can’t access the menu.
Does anyone know what will happen if I unplug the unit without un-marrying?
Thanks in advance.
2022 Ram 1500 EcoDiesel
I don't run my Tazer married, so I don't definitively know the answer, but I don't see what the harm would be.
Are there any other things that happened recently to your truck that might be pertinent? Like, did you get your windshield tinted?
Nope. Haven’t done anything to this truck lately.
I'd try unplugging it (with the truck off) and plugging it back in. Maybe just a power cycle will clear it up, if it's actually the Tazer. I haven't heard of this happening before with a Tazer, so I'm a little skeptical that this is the actual issue. My first guess is that some module got fried (which can happen if liquid gets behind the dash when getting a windshield tinted, for example).
I run my Tazer all the time in the live settings, but not married.
Your thinking was on the right track. The driver tail light had a crack (after someone had hit me in a parking lot I assume). Water got into the assembly and was causing things to go nuts. Unplugging it simply fixed everything. Crazy to think that some water in the tail light was causing my : windows to not work, center console and everything it controls to go out, power mirrors to not work, etc.
Glad you found the problem, sounds like trying to find a needle in the haystack.
Great news ! I don't know what you want your Tazer to do I use my'n not married for the pin-lock and amber drl's and stop-start. Glad you found the trouble.
I would like to know what you're using with PIN lock on your Tazer. I just installed one, and somewhere on the line I got all sorts of codes, one which was a Throttle Service code, and my truck is currently in the shop. I saw somewhere on the forum to stay away from PIN lock.
In my case, I was also messing with my key fob and wondering if that had something to do with my problems.
I always have the pin lock on and it works great no trouble with it. Tazer is not married. I love the PIN Lock only off if I go to car wash.
What is the point of the "Marry" feature if you don't use it? I'm still hesitant about using PIN lock.
Most of the time it's live settings start-stop,change to amber front lights, and pin-lock so I just don't marry it. I do use the pin-lock all the time I think it's great. Maybe I will marry it one of these day's
I did have it married but now I am using only live features so it's unmarried. why are you hesitent to use pin-lock ? if it is up to date it works great.
