longfiredragon
- Jan 12, 2021
Hello all, been a while since I have been on here, life just has a funny way of getting in the way. I did search on here but didn't see anything. I did not re-up my XM Guarding service, at least for right now. Truck is a 2020 with the level 2 equipment group, 12" display. Nav. doesn't work at the moment, you cant use the voice command to tell Nav. where you want to go any more. I talked to Mopar and they gave the instructions to reset the entertainment system which will supposedly reset the Nav. also.
So my question is will Nav. even work without the XM Guarding service? If so, have others reset the system and that was all it took? I was going to try the re-set tonight. I surly hope you can still use your Nav. in these trucks without XM which I am not a big fan of anyway.
Thanks!
Thanks!
