Nav Update locked
cfpotter70
Hello
New to the forum. I have a 2025 Ram Tungsten. Every time I shut down the truck the over the air nav update comes up. Truck is connected to home wifi. When I come back and restart the truck it says the update has failed. I have taken it to the dealer twice for this and they don't seem to have an answer. I was wondering if anybody on here might have had the same issue?
I had the same thing in my limited after selecting all of the US for map updates. Every night for months it would prompt to connect and update and every morning it would say it was not complete. Eventually one or two states updated, but I got sick of waiting. Not sure how fast it downloads, but it seems capped. So I just went to the maps update site and downloaded the Nav update, put it on a flash drive and it worked.
Thanks a for that info. Unfortunately they don’t have downloadable on the 2025. Has to be done over the air. I will look and see if I can deselect the downloads it is trying to make.
Mine is a 2025 Limited with the 14.5 in screen, worked just fine.
On my '25 U5-12, my first update failed from wifi also.
I went into Uconnect programming and turned off the wifi connection to my Home wifi (I think the range was at it's max and unreliable), and each update has worked since then.
Just something to try.
Hi there, if you're still experiencing this concern feel free to give our UConnect team a call at (877)-855-8400 for support.
Diamond
Ram Cares
I just got a 26 rebel. I tried doing it from my home wifi and no luck. I ended up using my cell data and connected it to the truck. I found that I had to restart the process every so often but after an hour I got all of canada.
