mch
Installed the N-Fab HPD1980CC-TX on my 19 Rebel. It was a simple bolt on, but getting the paint / coating off the mounting studs were a real pain. I started out with a hand brush, then a dremel with brass wheel, then a steel wheel, then a 90 degree air die grinder with a steel wire wheel (quick work with that). Would have been a lot easier with a lift, or even jacked up on jack stands, but I have a sloped driveway and the garage is full. Pretty solid product, but you lose some ground clearance, but I'm okay with that for my needs. On a side note, the box they came in where really beat up, and the bag with the nuts fell out of the box. Luckily the UPS guy said he found some hardware in the tuck, and wanted me to see if they went with the product (they did). He recorded the damaged box, in the event the bars were dented scraped, etc. Everything was bubble or foam wrapped, and that did the job.
