c3k
- Jul 22, 2020
Folks,
Here's my experience installing an aftermarket transmission pan for my truck's ZF8HP75 transmission. I'll run you through what I did, as I did it, so you can make your own decision. It'll be a bit long, but I want to be thorough.
The ZF8 transmission has a pan with a built-in filter. If you want to change that filter, you need a new pan. The kit (pan, bolts) costs ~ $250. RAM says it's a 100,000 mile fluid. Yeah...they make money when you need a new tranny. ZF says the oil change interval is anywhere from 2-4 years and 32,000 to 60,000 miles (depending on source, drive type, transmission temperature, etc.). With information all over the place, 40k or so seems reasonable to me to change fluid and filter in a transmission. So, I did it at 35,000.
I was not familiar with Pacific Performance Engineering, PPE, but many folks on this forum said they were solid. I went to their website: Transmission Upgrades Dodge/Ram
They offer 2 pans, both with replaceable filters. One pan is bigger (deeper) than the other. They are aluminum, with cooling fins, and that wonderful replaceable filter that only costs ~$30. That's FAR cheaper than the $250 new pan/filter combo. I chose the smaller of the two pans. This adds 1 quart of fluid capacity. (The larger one adds 2 quarts capacity.)
Here's where it gets interesting...the description/specs for the large pan reads:
Cool. Of course, I was not interested in the large pan, I wanted the smaller pan (which would still increase my transmission capacity by 1 quart:
See the difference? No? Neither did I. The small pan has NO COMMENT about WHAT FILTER is compatible. When I put that pan in my cart ($350, but I'd make savings on the lifetime of filter changes), what popped up was a window with "other people also purchased" and a filter and drain plug gasket. I tossed in several of the filters and drain plug gaskets.
Wasn't I surprised to find out the filters I bought (at the site auto-recommendation) were WRONG.
Here are the two filter types:
and
Now, the sharp-eyed will notice that the "Made to fit" line in BOTH filter descriptions do not match EITHER pan.
Okay. Pain in the ***. Good news? PPE already had the right filter bolted into the pan.
Bad news? The pan did NOT COME WITH A GASKET.
I called customer service. The wrong filters...I had to pay shipping and restocking fee. But, I can see (a little) how part of the blame for that is on me. However, their site is a mess when it comes to linking to compatible products and clearly delineating which filters go with which pans. Shrug. Learning curve.
But the gasket??? So, the CS rep said, "No, we don't ship gaskets. No, we don't sell them. Just re-use the one from the OEM pan."
Seriously? WTF. Re-use a gasket.
Now, I did have 2 spare ZF8 pans...for the HP50 in a BMW. (I purchased them from FCP Euro (<- outstanding outfit) for my son's Alfa Romeo.) I rationalized that I'd just use a gasket from one of them. (Those pans cost ~$65.)
So, I had the pan: 2010-2024 w/ ZF-8 Speed Heavy-Duty Cast Aluminum Transmission Pan
I also had some transmission oil. I decided to use LiquiMoly Top Tec 1800. It works on the ZF8HP50 in the aforementioned Alfa Romeo, LiquiMoly lists it as compatible with all ZF8s, and I really don't want to pay the outrageous sums for the Lifeguard 8 fluid.
Next, the pan swap...
and
