I finally was able to take my 2019 1500 in for all of the recalls including an abs recall. Anyway I never touch the headlight switch because it's set to automatic. I also hadn't driven it until about a month after the dealer worked on it. I was driving it the other DAY when I realized that I couldn't see the screen or the instrument panel as it was so dim. I tried to rotate the dimmer and nothing helped. I went to change the headlight setting and the center of it was pushed in to the point where I cant turn anything. It's currently flush with the dash and if I pushed it it will fall back into the dash. I called the dealer and of course they denied doing anything near that switch and refused to help. Has anyone ever experienced this? I think something is now ungrounded and affecting the brightness of the IP and screen. I also noticed that the light for whether its in 4 automatic or 2 wd isn't on either. As soon as it gets above 10 degrees I'm planning on snaking an inspection camera back there as I can't get my hand in it.
