Muzzys A/C hack location for ecodiesel?
Synergy26
Where is the install location for muzzys A/C hack on the 3rd gen ecodiesel. Pictures welcome please. TIA
My AC on my 2020 ecodiesel is nice and cold.
My 2019 Hemi it wasn't great.
Well in my 2020 I had it checked for the AC issue yesterday...and it was undercharged. So a replace and refill/top up was done and BOOM much colder than before. Been reading some trucks are coming undercharged?
Hopefully that’s all it was. Generally though, if an AC system is low and it is not from what you are describing as a possibility from the factory, then there is a leak.
2022 Limited bought in November 2022. AC works nice.
Later models will have a different blend door setup than what the earlier models have. There is a TSB out there somewhere that allows older models to get an updated system installed. I was tempted to do this, but don't want the oil change monkey at the dealership tearing my dash apart and screwing things up. Mine has always been weak, and finally had some freon added like Chris3058. It is way better.
Did you ever get an answer on this? I'd love to see a picture myself. I have clamped off both the hoses going to the upper portion of the firewall but haven't noticed much difference, blowing about 51* at 100* ambient
Anyone having a hard time knowing what hose
Seriously nobody has done this yet?
tried searching up and down the internet for help with this when I owned the eco diesel with no luck. where you able to determine the correct hose?
The hose is directly located beneath the overflow/coolant tank in the engine bay.
