New to the Ram world and love my 2020 Ram Rebel but as of recently I have had nothing but problems with it. It all started with a leaking rear window which was under the recall. I took it to the local ram dealer to get it fixed and they shot a bunch of silicone in the channel after having the truck for 4 days. Thought the issue was fixed but about a week later I noticed it was still leaking. I took it back in and the deal tells me I need a new rear window. (apparently now there tsb says not to replace the window) I called Ram cares and they said there is nothing they can do and it is due to neglect (all without seeing anything) anyway fast forward a few days after getting the truck back ( I did not have them replace the rear window as they wanted $2100) and now I get a service air bag light, service traction control, blind spot sensor not available, and park sense not available going off on the dash. A parking brake light, the e-torque light, a check engine light all came on as well. I plugged a code reader in and got multiple stored codes. Any suggestions where to start diagnosing? These lights will be on and then sometimes hours later after sitting locked will all turn off. I have a brand new agm battery I put in a week or so before the rear window leak so that is new. ( I did check the battery voltage with a multi meter with the truck running and it was 14.3 volts. When turned off it was at 12.3 volts which seams a bit lower than I am used to in other vehicles). I am at my wits end with this truck and have only owned it for a few months between the leaking rear window and now the electrical issues I don't know which way to go.
AIRBAGS
#U0001-00
can c1 bus - no subtype information
can c bus
stored
#U0154-00
loss of communication with occupant classification module - no subtype information
lost communication with occupant classification module
stored
ANTI LOCK BRAKES
#U0140-00
lost communication with body control module - no sub type information
stored
#U0151-00
lost communication with restraints control module - no sub type information
lost communication with occupant restraint controller (orc)
stored
#U0159-00
lost communication with parking assist control module
stored
BODY CONTROLLER
#U0002-00
can c1 bus off performance - nessuna informazione a supporto
can c1 bus off performance - no subtype information
can c bus off performance
stored
#U0184-00
lost communication with radio
stored
ELECTRIC POWER STEERING
#U0140-00
c1_igw1 message from body control module (bcm) is missing - no subtype information
loss of communication with body control module (bcm) - no subtype information
stored
#U0415-00
invalid data received from anti-lock brake system (abs) control module ""a""-
message counter fault on brake2 message (1) - no subtype information
stored
#U0002-00
stored, warning lamp
ELECTRONIC SHIFTER
#U0140-00
lost communication with body control module (bcm)
lost communication with bcm - missing message
stored
HYBRID CONTROL PROCESSOR
#U0001-00
can c bus
#U0140-00
INSTRUMENT PANEL CLUSTER
#U0159-00
stored
#U0422-00
implausible data received from body control module
stored
#U0002-00
stored
INTEGRATED TRAILER BRAKE MODULE
#U0151-00
stored
PARK ASSIST
#U0002-00
active
#U0140-00
stored
#U0155-00
lost communication with cluster/ccn
stored
#U0121-00
lost communication with anti-lock brake system (abs) control module ""a""
stored
#U0101-00
lost communication with tcm
stored
#U0100-00
lost communication with ecm/pcm ""a""
stored
#U0137-00
lost communication with trailer brake control module
stored
POWERTRAIN CONTROL
#U113E
lost communication with intelligent battery sensor ""a
historical
#U0164
lost communication with hvac control module
historical
#U1199
lost hood ajar switch voltage message
historical
#U0432
invalid data received from multi-axis acceleration sensor module ""a
historical
#U1133
lost stop/start switch 1 message
historical
#U1134
lost stop/start switch 2 message
historical
RADIO FREQUENCY HUB
#U0140-00
stored
STEERING COLUMN CONTROL MODULE
#U0140-00
stored
TRANSMISSION CONTROL
#U0140-00
can - bcm absent
stored
#U0151-00
lost communication with occupant restraint controller (orc)-
stored
#U0120-00
lost communication with starter/generator control module
stored
AMPLIFIER
#B146F-13
channel 4 audio speaker output-circuit open
active
COMFORT SEAT AND WHEEL MODULE
#U0184-00
stored
HEAT VENTILATION AND A/C
#U0184-00
lost communication with radio - no subtype information
stored
HEATED SEAT
#U0184-00
No description for: U0184-00
stored
RADIO
#B221E-00
radio internal - no subtype information
stored
AIRBAGS
#U0001-00
can c bus
stored
#U0154-00
stored
ANTI LOCK BRAKES
#U0140-00
stored
#U0151-00
stored
#U0159-00
stored
BODY CONTROLLER
#U0002-00
stored
#U0184-00
stored
#U0140-00
stored
#U0415-00
stored
#U0002-00
ELECTRONIC SHIFTER
#U0140-00
stored
#U0001-00
can c bus
#U0140-00
#U0159-00
stored
#U0422-00
stored
#U0002-00
stored
#U0151-00
stored
PARK ASSIST
#U0002-00
active
#U0140-00
stored
#U0155-00
stored
#U0121-00
stored
#U0101-00
stored
#U0100-00
stored
#U0137-00
stored
POWERTRAIN CONTROL
#U113E
historical
#U0164
historical
#U1199
historical
#U0432
historical
#U1133
historical
#U1134
historical
RADIO FREQUENCY HUB
#U0140-00
stored
#U0140-00
stored
#U0140-00
can - bcm absent
stored
#U0151-00
stored
#U0120-00
stored
AMPLIFIER
#B146F-13
active
#U0184-00
stored
#U0184-00
stored
HEATED SEAT
#U0184-00
stored
RADIO
#B221E-00
stored
