Mug flaps 2025 1500
I installed these on my 2025 longhorn in about 40 minutes. If i remember correctly, its 4 factory screws some double-sided tape and a plastic pop rivet. very easy You do not have to remove the wheels.
Put fronts on and then realized the rear set is wrong part. Here’s the front in 25 Laramie with ORG
Look like the belong there! Thanks for the photos! Take long to install?
Put the same on my 2025 and took me about an hour to install all four. Just make sure you have the plastic rivet tool before installing.
Saw the title and thought of this..
Would be nice if mopar didn’t list 2 different part numbers for the 25/26 Tungsten as compatible. SMH.
82215488AC and 82215487AC
a
ny luck on which are the correct ones for the tungsten?
a
I just ordered the ones recommended above to my local MOPAR dealer. So fingers crossed. I think they should be fine as the tungsten has what I assume they consider extended arches.
I have a 2026 Laramie. These are the mud flaps I ordered and received from Mopar. Install took about 10 minutes for each flap.
After I placed my initial order, they asked for my VIN to ensure the parts fit. Turns out I had ordered rear flaps that only fit the RHO. They changed my order to the correct ones which are listed below.
82219073AAMolded Splash Guards, Rear$64.38
82215488ACMolded Splash Guards, Front, For Vehicles With Production Fender Flares$66.76
Does the Laramie have the fender flares like the limited and tungsten?
My Laramie has fender flares. I’m not sure if they’re standard or part of one of the packages the truck came with.
I ordered a set of front and rear flaps from Weathertech for my '25 Longhorn! Perfect fit.....about 10 mins/fender. And they work....and look even better!!! Recommend them highly!!
