KNGSNK11
- Feb 3, 2020
Do you know the consequence of removing that butterfly valve?I don't even have a Rebel and I'm getting 22 mixed city/highway. It's a bit less than I expected.
As far as Pedal Commander goes, all it does is amplify the electronic throttle signal so that you press the pedal less distance to get the same throttle input that you got before with that amount of distance. It does nothing to correct the lazy transmission programming (which is where most of the lag comes from) or the turbo lag or the butterfly valve in the tail pipe that chokes off exhaust flow to build backpressure. The entire powertrain calibration on these is sloppy and simply amping up the throttle input is a band-aid.
I noticed it when I crawled under my truck when I first got it but had no idea what that was for.
