Idahoktm
I'm glad I'm not the only one that doesn't understand. I thought it was the Oxycodone I'm on.What are you trying to say?
No kiddingWhat's a gas attendant?
When I was a little kid I'd laugh every time when my dad would tell the attendant to fill er up with ethyl. I used to wonder who she was.No kidding
Last time those were around here was back in the 70’s. “Fill er’ up with leaded check the oil and wash the windows while your at it.”
Ah the good ole’ days.
Remember, sharing is caring.I'm glad I'm not the only one that doesn't understand. I thought it was the Oxycodone I'm on.![]()
correct 26 gallon tankAnd a 26 gallon tank
The gas tank was filled with 23.42 gallons of gas.Not sure what you are trying to get at. I've ran my tank for 15 miles after DTE read zero and still only got 24 gallon in the tank.
You are correct, after checking VIN# specs. my tank is 26 gal. Thank youFor starters, I would have slapped the **** out of the attendant for "topping off" my tank. As others have said, you obviously do not have a 23 gallon tank, either that, or you got screwed by a gas pump that isn't accurate.
As for why your DTE hasn't dropped, if the attendant "topped off" the tank, they over filled it. Your DTE mileage won't go down until the fuel level sensor sensor starts to drop, which will take longer since the tank was over filled.
