muchocheko
- May 12, 2020
My 2019 Ram 1500 Tradesman doesn't have the running board mounting bolts on the inside of the frame. Only one or two of the holes are threaded.
The running board kit I got assumes you have those bolts already installed.
Do I just get the install kit that lets you install a threaded nut inside the frame, then just use the appropriately size bolt?
I've seen other references to this, but can't find any details on this.
Thanks!
Thanks!
