Motofab Complete lift Kit
Apettit13
Hey all,
I have weeded through hours and hours of threads, and can’t seem to find anything on this.
motofab has a 3 inch Front and 2 inch rear level/lift kit. I’ve seen quite a few good reviews on the typical motofab levels, but haven’t found anyone running this style spacer lift.
many one have it? How does it ride? Quality up to par?
i attached the link below. Thanks in advance!
I just installed this on my 2020 1500 4wd .. like it, rides same .. Just did the 2.5 front kit though..
Would you mind posting a pic? Have you changed the tire and wheel setup yet?
Stock wheels tires.275/55/20 all season want new ones ,waiting for spring I'll post a pic soon .
Oh no Alignment went perfectly fine Just need to figure out the best tire size. Any suggestions?
Hm, not sure i haven't added any aftermarket lift to my Rebel yet, so I haven't looked much into the other tire size choices when you lift the ram up 2".
4 wheel parts tech told me with a 2” leveling kit installed, you can run most 33“ tires and with a 2.5” leveling kit then 35“ tires could be installed! But I would fit check the tire you pick out with your rims on this truck first! just to make sure nothing interferes or rubs In a tight turn.
Did you install the 3” up front?
Yes I installed 3 in h front and 2 inch rear kit. Attached is the before and after, after is on top. Still haven’t got new wheels and tires yet, but planning on those as well as new uca
Any issues w the 3” level?
Wondering if it will cause UCA/cv issues if I don’t beat on the truck.
Thanks.
Thinking about doing Motofab 3 front 2 rear
Does anyone have issues yet with this kit ??
Do you have any issues with it
