Mopar security lug nut model number?
RAMMER80
Does anyone know the mopar lock /security lug nuts that the gen 5 1500 bighorn takes? I bought some that but but clearly not for the rams wheels. They have a grey part that protrudes that clearly should be used for different wheels.
RAMMER80
Found this list: Buy 2020 Ram 1500 DT Wheel Lock | All Mopar Parts You could probably pick the part # you like and search that to see if you can find a cheaper set :)
I’m wondering if I have the correct ones then. I bought these exact same ones. That grey ring that surrounds the lug nut that I drew a red arrow to looks odd. It doesn’t bother me it’s more that I thought I had the wrong ones.
Does everyone’s oem ones look like this? Any of your guys pictures would help.
Rlaf75
Takes potshots
I believe that gray part is a spinning collar. Its there to prevent someone from clamping on a pair of vise-grips to remove the nut.
Belvedere
These were on my truck. Keep thinking I'll remove, but haven't.
scottmoyer
I removed the factory lock set from my Rebel wheels. I'd be interested in selling if anyone is needing a set.
