How much weight does the ORG add to a base model truck?
What all comes in that pkg... skid plates, better shocks, 1" lift (due do diff springs I think)?
The ORG includes:
- Tow hooks
- Front suspension skid plate
- Transfer case skid plate (on 4x4 models only)
- Electronic power steering skid plate
- Fuel tank skid plate
- Rear electronic locking axle
- Front/rear off-road calibrated shocks
- Hill-descent Control
- Off-road decals (both sides, rear quarter panel, not included with Rebel)
- All-terrain tires
The press release also said it has a: "unique rear suspension geometry (Rebel and 4x4 Off-road Package) to keep the tires in traction." That may simply mean that 1" higher the trailing arms are at a better angle. The shocks are just different valving.
The ORG is less expensive than the protection group and electronic diff purchased separately. As a result, it can be a good value if the 1" raise in height is desirable or not an issue. It is the only way to get the hill-decent control. If the Safety Group is ordered and the Trailer Tow Group is NOT ordered, it comes with a surround camera, not available on the Rebel. It can be useful in tight places.
With the 4-corner air suspension, FCA does away with the normal setting making the 1" higher Off-Road setting normal with no speed limit and the retains the off-road 2 as off-road 1. That gives the option of 2" higher at low speeds.
The all-terrain tires are an OEM Falken called a Wildpeak A/T3WA but not the same as the retail Wildpeak A/T3W. The OE tire is load range C LT in 18" size, metric in 20" size. The retail A/T3W is load range E in the 18" size, still metric in 20" size although other 20" models are load range E LT tires. With 1" lift it should fit 34" diameter tires (e.g. 275/65-20) without even a level kit. People have fit 35" and 37" tires.
Note that the skid plates reduce the break-over angle equivalent to loosing over an inch of lift. Rock sliders probably take away more. 4"+ Lift kits for the Ram leave the front lower controller arms at the OE height with respect to the wheel and may even lower the front differential with respect to the body. As a result, they increase break over angle but not necessarily ground clearance other than that gained from allowing taller tires.
Unfortunately, although on a 2019 link, FCA is only downloading the 2018 weight guide. Folks have estimated the ORG at around 75#. Maybe they will fix that for 2019. In another thread, people have discussed rock sliders for the Ram 1500 DT, which now seem to be available. They weigh around 120#, and currently only for the 26 gal fuel tank.
