Douglasmtn
- Dec 23, 2019
I took my 2019 1500 Laramie (5th Gen Crew Cab) into my local Ram dealer in CO to have a Mopar 2" lift installed. However, a few hours after I dropped the truck off, the dealer called me to let me know that the lift would not fit my truck because I have the longer bed (6' 4"). Has anyone else had this problem and if so, why won't the lift work on the longer bed since the suspension is the same?
Next, if I can't use the Mopar lift are there any other 2" lifts, not leveling kits (I still want the rake), out there that you would recommend? I am not looking to go very high as my goal is to get the ground clearance back up to what my 2011 Chevy Silverado had, not to necessarily put on larger tires. At this point, the stock 8.5-9" of clearance does not work for me as I have already torn up a set of aftermarket stepup/nerf bars when I bottomed out going over a snow/ice pile left by the plows - I need something in the 10-11" of clearance for home and work.
Thanks in advance for the advice and suggestions!
