Method MR305 with 285/70R18
sp_ram
Hi Everyone,
I'm about to pull the trigger on a set of wheels and tires after much research. I just want to make sure that I'm making the right decision and that it will look good. I'm looking at a set of MR305s 18" -12 with LT285/70r18 tires and a 2" level. Is anyone running a similar set up?
Any guidance would be much appreciated. Thank you.
boogielander
Method 305NV 18x9 -12mm
Falken Wildpeak AT3W 35x12.5R18
Fox 2.5 Performance Elite DSC Extended Travel at factory 2" in the front
Fox 2.5 Performance Elite DSC with Carli Rebel HD Rear Springs 1" with ~550lb in bed
you're gonna be fine, just make sure your 2" "level" is actual coilover and not spacers or pucks.
sp_ram
Thank you both!! Excited to get it ordered and on the truck.
Availingfaith
Method 305s -12 offset on 35" Nexen Rodians MTX with 3.5" lift.
I ordered the flush mount center caps from Method which look a lot better IMO than the ones that come with with the most of the 305s. I think the flush mounts come standard with the Double Black but all the others you'd need to order. On our trucks with the -12 offset, the standard center cap sticks out kind of far. The pic by Boogielander show the standard caps. They look kinda cool on his build since they have that old school locking hub vibe which fits with the overlanding style.
