I have '19 Limited which has the 12" Uconnect.
Myself and the wife have set up the memory seats, mirrors, and our separate radio preset stations settings with mine being setting 1 and hers setting 2.
We then went on the SiriusXM setting and created two separate profiles. Hers is the star avatar and mine is the sunglass avatar.
I then set the link to each key fob following the simple "ignition in off position, press setting # (1 or 2), press S, then press setting # (1or 2) again, then press LOCK on fob. Pretty simple deal.
Prior to doing all this I read the user manual I downloaded on how to do all of this and wrote the instructions down on paper of which I took out to the truck to do all this. what I am saying here is that there is NO WAY I did the set up of the memory settings and fob linking wrong.
HOWEVER........while the separate key fobs will set the seats and mirrors as they should be it will NOT change the radio presets to the correct key fob. If the wife has driven the truck and then I go out to use it, reading my fob, the seats and mirrors move to my settings but the radio will remain on her profile and radio station settings.
What I have done is; unlinked and linked the fobs, deleted and redone the Siriusxm profiles and radio station settings, and re-adjusted and saved the seat and mirror memory settings. Done this so many times I have lost count. And done all of those in various order.
I am so frustrated with this!!
Went to dealership yesterday and they had no clue. Tech said no current software updates are available.
ANYBODY......can anyone give me some help or ideas of what to do or try next??
Sorry about the long rant...
