dforaker79
- Feb 10, 2024
So I replaced all of the rambox wiring and the jumper coming off the bed harness because the drivers side rambox button does not work on my 2020 Longhorn. I found a pretty melted plug and wires for the lock actuator jumper. After changing everything and cleaning up the pins on the existing connectors, it still doesn't work. Anything that can cause this plug to burn and the lock not work? The actuator, lid wiring, and lights are good because I took the lid off and tried it on the other side. There is nothing else wrong with it. I even went checking all the fuses. Everything seems fine.
