Maxxd7000 lb dump trailer surging
jimbojames!123
My maxxd dumper seems to feel like it's surging when I go above 40 mph.i felt the brings and drums and they are not hot.im using an Hutchins impulse trailer brake set on 10 when empty,20 when loaded with 3000-4000 lbs.i also have my drop hitch set so the trailer rides level.its also incredibly difficult to steer backing up.esp trying to recover if you over do it.its not happening.you have to pull forward and start over. What could cause these issues?I'm attaching pics of my hitch and trailer.
Your issue with backing up is probably due to the length of your hitch , which might even be contributing to heb surging feeling.
Get rid of that janky setup..
When the collar lock of the trailer is a good 2.5’ from the trucks hitch I’m not surprised there’s surging. A bunch of moving parts.. you got a drop hitch that adds a 8” then for whatever reason, thats connected to a receiver that adds another 8” to the length then the actually hitch ball that adds another 8”.
Just for example is what you should be using keep the length at minimal as possible that collar should be rather close to the hitch receiver/ball. You want the hitch weight close to the receiver. All that length isn’t helping you. Make sure whatever hitch you’re using is rated high enough for that trailer and load and that your load is within that trucks capacity.
I agree. That hitch extension is your problem..that creates leverage on receiver..I pull a much heavier dump loaded with no issues
No members online now.
