RKPhelps
- Apr 4, 2018
I have a 2019 Ram 1500 Limited with 5.7L Hemi, Air Suspension, 3.92 ratio, 5.7 bed, and the 22" Wheels and Tires.
When I check on Ram's website using my Vin# it gives me a Max Payload of 1840 lbs, When checking the Ram towing chart for this configuration it gives me a Max payload of 1800 lbs. Now when I look at my sticker on the front door jamb it says the Max Payload is only 1428 lbs.
Anyone else have this,?
If true can you explain to me how they arrive @ 1428 lbs?
It doesn't make sense to me because the max load rating on each tire (285/45/R22XL 114H) is 2601 lbs and if you divide the 5300 lbs truck weight by 4 and subtract that from the 2601 lbs you end up with over 1300 lbs extra capacity per tire x 4 = over 5200 lbs.
So if the tires aren't the limiting factor and all the other sources say the truck itself can handle in excess of 1800 lbs why does my door jam say 1428 lbs?
Thanks Rob
Thanks Rob
