Map light issue
omalley72
Swapped out my bulbs for LEDs last night. No issues. All worked as they should. This morning when I started the truck, the right map light would not turn off. I pulled the cover and wiggled the bulb around a bit...no luck. Once I shut the truck off, the light went out. It seems the light only stays on while the truck is in ACCY or running (all others work as they should). I pulled the assembly down and replaced the bulb, again no luck. I put the original bulb back in, no luck. I disconnected the neg battery terminal for an hour hoping that would solve the issue. Well, it didn't. I figured when I take it in for it's first oil change I'll also have them look at it, unless anyone here knows what the issue could be. I know with previous generations this was an issue but was hoping that would not follow to this generation. Truck is 5 days old.
