lug nuts
patsfan
Anyone know what style of lug nuts fit the steel wheels? Do the stock cone style off of the 20" bighorns fit? I have a set coming for winter wheels and wondering if I need to get a different set.
Which steel wheels oem? If so you should be fine but just call the parts Dept at the dealer to confirm. If it’s a non oem wheel then it will be dependent on the wheel and you should check with manufacturer.
I have OEM steel wheels like what a tradesman would come with as winter wheels, stock lugs worked fine.
