Does anybody know the weights of the P tires VS the LT ones? I'm curious how much more my Rebel weighs due to the off road tires over a non off road setup.
Not totally sure what your asking. but if your wanting to compare how much more LT tires weigh vs P tires. here is the duratrac in 275/65r18 size, for comparison. they don't make the 275/70r18 duratrac in P
p rating = 45lbs = 16/32 tread depth = 2756 weight capacity
LT C range = 49lbs = 18/32 tread depth = 2535 weight rating
LT E range = 50lbs = 18/32 tread depth = 3415 weight rating
so it looks like the weight is mostly from the extra tread depth rather than the weight capacity. the p rating tire will get better mpg due to shallower tread depth.
the 275/70r18 on the rebel weights 55lbs. most 275/65r18 all seasons like would come on a laramie or big horn are around 40-45lbs a tire.
If you have the Wildpeaks; they will be significantly higher that the Duratracs.....Duratracs are pretty light for off road tires. The Wildpeaks would be about 61 lbs.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
