Rock Crawler
I’ve searched the forum and Google and I can‘t really find much info on the Ridetech units. I currently have the Maxtrac 2” front lowering kit, and I’m not really happy with it. I think the struts are just too soft. On dips or humps, the tires rub the wheel wells. Both sides have holes where the tires have worn through. I’m considering front coil-overs, but I have only found 2 options so far. Ridetech says that you must use their upper StrongArms for proper alignment and to correct ball joint angle. I currently have the Maxtrac Camber Arms, so surely those will work with any coil-overs I choose. It seems as though the Belltech might be the better choice based on price and the compression adjustment. I’m just not sold on Belltech. I know they don’t have a great reputation for quality. I’m just curious if anyone can provide any feedback on the Ridetech and Belltech units.
Ridetech - $1,040.00
Aluminum Body, mono-tube design
Adjustable height 1-3”
Adjustable rebound
No compression adjustment
Belltech - $760.00
Steel construction
Adjustable rebound
Adjustable compression
Adjustable rebound
Belltech - $760.00
Steel construction
Adjustable rebound
