Lower Control Arm Ball Joint Squeak
Louhound88
Has anyone ever had a lower ball joint squeak? Mine started squeaking just this past weekend and it took me a few days to figure out exactly where the noise was coming from. It's definitely the lower ball joint, but I'm trying to assess how much of an issue this is.
I had a 2.5" level spacer (motofab) installed about 12,000 miles ago, so I'm not sure if that would negate any warranty repair. I'm setup to take it to the dealer for service tomorrow morning, so i'll find out then if it's warranty and how quickly they can get the new LCA in.
Trying to decide if I want to even have it replaced under warranty if it's just going to fail again. Or should I move onto a better front suspension setup overall (shocks,struts, UCA, LCA) and avoid any other issues.
outdoor7or24
What did you end up doing?
I think my lower ball joints are squeaking too, factory setup..
