Looking for the best of both worlds.
TxHouse
I’m just in the planning stages of getting new tires. Maybe 10k left on the stock Falken tires.
I have a 2019 Longhorn 4x4 ORG with the 3.21 rear axle. I’m thinking of bumping up in size to the 275/65/20 in either the new RT Trail tire or the Recon Grapplers. Both tires would be in an SL load range. Both tires show to only be between 3-4 pounds heavier per tire than factory.
My questions are would I be hunting for gears all day on the highway and being this light of a tire, would I see the same hit in mpg as I would with a load range E tire?
What size and tire do you have now?
Im my experience the slight change in tire weight wont make a HUGE difference. The tread type and tread width combined with your driving style will make a larger impact on gear hunting and mpg.
From personal experience I find the function over form approach ends up best with tires. IE I have Michelin LTX MS2 tires on and they are not particularly exciting looking...but they provide the most bang for my buck with tire weight / weather capability / towing / beach driving / tread life / ect. So keep the purpose of your tires in mind when making that choice.
I currently have the stock size 275/55/20 Falken at3wa tires. I’m looking at the AT tires because I do like to explore off the beaten path. Nothing too extreme, fire roads and usually level 1 trails.
I replaced mines with 275/60/r20 Nitto Ridge grapplers XL rated and had to fixed my speedo. I ran the truck for a while and I did not experienced too much changes but ONCE I FIXED THE SPEEDO WITH ALFAOBD I can really feel the difference. The truck runs so much better calibrated.
Thanks y'all for the responses. I think I know what route I need to take.
I did a BUNCH of research on tires. If you can, also look into TOYO Open Country AT3's. They are similar to the NITTO stuff. I have had mine on my truck for a month and they are incredibly quiet but still look aggressive. I upsized like many others and they didnt change gear hunting or anything.
I've had three sets of the toyo AT2's and they were great tires. The reason I did not look at the AT3's this time is because they don't come in a standard load in that size but if I decide to look at a 285/60/20 or 275/60/20, they will be at the top of the list.
