Looking for advice on buying a new 5th gen 1500
The more i read up about buying a new truck, the more I am finding it is better to wait. Because prices will only be going down over the next 4 months. I have spec'd out a few Ram 1500s and will wait for what I want.
I dont mind flying to OK and driving one home.
Supposidky the 6'4" bed does still allow for suspension lower/raise. And a 33gal tank option!
Does an extended warranty get honored at ANY dealership?
This is absolutely correct. The only issue is if you go low enough to effect pinion angle, it is a little trickier due to the two piece driveshaft. 4” plus and you will most likely need to adjust the pinion angle.
