I had it on for a few weeks and driven it in the rain. A few areas had some leaks but nothing major. I also bought the tailgate seal kit but have not installed it yet. I'll let you know if it makes a big difference once I install the package. Overall I think the new design eliminates most of the rain issues. Regards DHAny idea how well the Lomax will seal out the rain?
Not really Wingman those are the lock down tabs which secure each section when you close the cover They heavy duty rubber and if they get in the way of any thing I will just remove the cover until I’m hauling. The cover is 60lbs and as you noted pretty easy to remove.Thanks DH. I like how clean this looks on your truck, and how easy it is to remove. Any issues or concerns with the tabs protruding from the Lomax rails?
You should only have to seal up at the top of the tailgate (corners), not the lower portion. See pics
Mine came with my Truxedo Sentry because they already knew about the gap on the new tailgates so they included some weatherstripping. I have ramboxes so I’m not sure if that changes the gap at all (I wouldn’t think so) but the dimensions on each piece (left/right side) is:
4.5”L x 1.25”H x .5”W
So you don’t have to buy any “kits”. You can go and buy any pieces of foam or wheatherstripping that you can cut to that size. Even if it isn’t adhesive backed you can always put some 3m double stick on it.
Thanks Patsy I will take your advice on the install.You should only have to seal up at the top of the tailgate (corners), not the lower portion. See pics
You can find them at SharpTruck.com. Ram Gatorback Ramhead Logo No Drill. SKU TH-GCR34F-RV-GCR35R-RV.Those mud flaps look nice. Where did you get them from?
