Ardeedunn
I know that is is a common upgrade to swap the Laramie style Cluster into the Tradesman and base Big horns. But, has anyone swapped a Digital Limited Cluster into another Ram yet? Can it be done the same way?
hmmm not sure why ...Thanks, but there was no link shown
You are the all digital cluster. No one has been able to swap that in yet but it is being worked on as an option.Thanks, got it. But the Cluster I'm referring to was the latest cluster on the Limiteds that is completely different than the others. It appears blank until powers up.
Will definitely need UC5 and different firmware I bet also.You are the all digital cluster. No one has been able to swap that in yet but it is being worked on as an option.
Probably not new firmware, but yes, UC5 because I think that's where you do the customization.Will definitely need UC5 and different firmware I bet also.
It's differnt firmware.Probably not new firmware, but yes, UC5 because I think that's where you do the customization.
I know it's different firmware. I have a lot of experience with that. But the signals are still the same.It's differnt firmware.
2023s and 2022s use differnet firmware even though they are both UC5.
Someone has put the 2023 firmware on a 2022 and it worked though, but I don't think 2019-2021s (UC4) would work without swapping to UC5 first.
Just noting it as another likely step.
100%The truck I wanted to swap this into is a 2022 Ram 1500 Bighorn. What are the chances that this new cluster would work?
Pretty good.The truck I wanted to swap this into is a 2022 Ram 1500 Bighorn. What are the chances that this new cluster would work?
