Limited Air-Ride: Nitto/Wheel sizing References
PoppaPig78
Sharing my data collection as I work to select wheel and tire size for my 2020 Limited without the Off Road Group.
Tire & Wheel References
Plan:
- Revel Links with 2" spacer on the front, rear links too.
- UCA's are wait and see what the resulting angle is. It seems 2019's and 2020's may have variance in the UCA's used and whether the ball joint can pivot enough to accommodate the ~2.5" raise.
Still Deciding:
- -18mm or 0mm wheel offset. I want just a bit of wheel pop with 11.5" wide Nittos
- Tire size leaning 285/65/20R
Preview of the linked Doc:
TechDaddy3x
Arkansas
If you give me about 3-4hrs i can help.... i just had the dealer install the daystar spacers and revel links on my 2021 Limited w/ ORP friday and have an appt to get Fuel 20x9 +20 w/ 295/60r20 on later this afternoon. Thats a 34.5" tall tire.
TechDaddy3x
Arkansas
Here it is....wheels sit flush with fenders and ride is awesome!
PoppaPig78
Just did mine :) Did yours also end up with the front slightly higher than the back? Mine is by ~3/4" so I need to try to adjust them.
