Limited 22’’ wheels
RichRios
Can someone that has a Ram limited with 22’’ wheels take a pic with a ruler in front of one of the lug nut openings. Trying to get the measurement of the opening for lug nut locks. Thanks
thefastz
I don't have the measurement offhand but I did order https://moparonlineparts.com/1500-wheel-locks-p-8558.html. They are the same width but they are not the same length as the factory lugs, look to be about 1/2 to 1 in longer. I am using them for now but I may replace them in the future with something closer in length, so interested to see what you decide.
RichRios
thefastz
Ah interesting, I can measure it tomorrow, if that helps. If you want I can also measure the stock lugs tomorrow. Would that be better than the openings?
202snowman
5thGenRams Supporter
Rochester, NY
They look a little oblong to me honestly and I can't get a good measurement with a tape measure (battery is dead in my veniers ) WAG looking a tape measure is 1-1/2 inch side to side, 1-5/8 tall.
RichRios
Yes if you can do both. Thanks!!!
thefastz
I took a set of calipers and did a couple measurements. Lugs are 0.875 inch across flats. The opening as around 1.50-1.55 inch diameter (hard to get in there for a accurate measurement)
I was just about to walk out and take the measurement, thanks for this!
