Lightest tire in 33 or 34
Chan_man808
I’m sorry I am going to be “that guy”, yes I did search and got some ideas.
Looking to go with a bigger tire after my 2 inch level/lift, this thing will see light off-road if anything at most. My wife drives the truck and has a lead foot as is bad boy is barely getting over 14 mpg. So I’m looking for the lightest tire I can get, without putting me down in the 12 mpg range 😂. looking to go with an all terrain at most and maybe even a highway tire if it has a decent sidewall (need a little bit of looks 😂), spent time looking at the 275/65/20 and I like the Bridgestone dueler at revo 3 (51 lbs) and the pirelli at (58 lbs), nitto terra grappler (47 lbs). Any suggestions welcome, thanks for the input.
theblet
I went with venom xt 275/60r20 tires. 4 ply and not too heavy. They are 33”
theblet
it’s harder to find 4 ply above 33” as well.
jl13
boyle heights, CA
found about these after I had install my upgrade
nitto recon grappler a/t
these come in an LT and SL - at 48 lbs - 275/65/r20
BilletMotoRam
Just put on some 275/60-20 33” cooper rugged treks 48lbs. I was in the same situation, didn’t want a heavy load range E tire. Overall happy with them so far, they also have the 3 peak snow rating.
RBurr
Do they stick out any from the fender flare or are they pretty much flush? Do you have a pic?
BilletMotoRam
The tires sit in about 1”. So not flush. But I did order Bora wheel spacers 1” front & 1.25” rears so they will equally be flush, maybe stick out a tad. I will post pics when I get them installed. Bora makes them as you order so it will be about a month.
CalvinC
Colorado
May have to order from TireRack or hunt further, but there is a Rivian-spec 34" tire (275/65/20) from Pirelli that weighs only 48 lbs.
Beyond that it will be hard for any LT tire to beat the Bridgestone Revo3 in any given size, until you step down to P-metric (non-LT or Load E) tires.
JRW323
Minneapolis
34" sizes with SL load ratings that I have found.
275/65/20
Nitto - Terra Grappler (older tire tech)
Nitto - Recon Grappler
Pirelli - Scorpion AT+ (Rivian Spec)
Ramgoose
Good choice! Falcon HT 275/60/20s are nice too. Aggressive sidewall like the AT3’s but more highway tread.
theblet
Those are nice too. The price for the venoms we’re $1000 cash. I couldn’t pass it up. These hum on the road, they are pretty aggressive
Chan_man808
275/65/20
Very interesting I’ll look into the pirelli scorpion (rivian spec)
Chan_man808
These caught my eyes also it’s a highway tread with an aggressive sidewall almost exactly what I was looking for.
