M
Billet automotive buttons. It’s all customLink to switch, or did this come with the light bar?
how about a pic of the light bar ?
The rough country kit. Going to be upgrading to a better bar as the output on this one is lacklusterNice what bar did you go with.
The same location as the rough country?Spoke with baja and they said their kits should be rolling out soon, s8 for the affordable and the onx6 for bad ***.
Well any 20” bar should work with what I have now as long as the dimensions are the sameYes but I believe they made their own bracket.
Do you like the little 6” bars right on the side of the ram decal tho? Thought it looks sick. And would you recommend to go bigger on the lower part of the grille? Like 20”Well any 20” bar should work with what I have now as long as the dimensions are the same
Yeah I like the look of the 6” lights. They are a bit of a flood light. The lower is 20” but if you want good output go with the Baja kit. I’ll be upgrading my bar in the springDo you like the little 6” bars right on the side of the ram decal tho? Thought it looks sick. And would you recommend to go bigger on the lower part of the grille? Like 20”
Or if you can fab brackets stuff a 30” in there.Do you like the little 6” bars right on the side of the ram decal tho? Thought it looks sick. And would you recommend to go bigger on the lower part of the grille? Like 20”
