Scram1500
- Jan 15, 2020
I like to stick with OEM, but will use Wix occasionallyAny recommendation regarding the oil filter? K&N, Mobil 1 ?
I appreaciate the note @silver billet I am going to give it a try next time, I run the truck. I makes sense to be able to cranking the engine and fill with oil the lifter without actually turning it on.Royal Purple or Fram Ultra/Endurance, both of these use better ADBV.
If you're gone for an extended period of time (week plus) then you can also use the "clear flood" mode; push gas all the way to the floor, hold brake + gas, push start with gas all the way to the floor - it will crank for like 10 seconds and build pressure without firing up.
Im gonna have to try this : )Royal Purple or Fram Ultra/Endurance, both of these use better ADBV.
It works, what I do.Im gonna have to try this : )
It does more than build up pressure. It still pumps the lifters and turns the engine at around 300 RPM. It's just using the using the starter motor to operate the engine instead of internal combustion. Not sure this is really solving any problems.
