lifter issue fixed or not?
laramie4x4
CT
Doing some research on the HEMI 5.7 and seems the lifter had serious issues which destroys the camshaft - see video here:
Is this issue isolated to some older model year or does it still exist on current models?
Idk ran an 03 hard for 167k. Had a tick on startup but never an issue. 2020 now with >4k we will see. I do my own oil and maintenance.
From what I understand it's part of an inherent design of the camshaft being so far away from the lifters, unlike a small block Chevy for example. Since the lifters are fed oil by oil splash from the rotating assembly, that they can be starved of oil if you idle too long with lower oil pressures. 1,500 rpms or higher is needed to keep it well oiled.
They introduced higher quality roller pins, a few years ago, but that won't help if they aren't getting enough oil. It's recommend that you occasionally rev up the engine to get the upper part of the valvetrain lubricated well, use a good quality synthetic as well to help with this. Essentially gun it from time to time when you can do so safely is the most common layman advice. Most of us do that anyways, since it's a Hemi and kinda the point right :)
As 2020Big4x4Horn mentioned, he ran his 03' hard, which is why he probably didn't have a problem. He got it well lubricated, it's running it too gingerly that may cost you.
Of course no one actually knows of the current Hemi engines in the DT gen RAMs have been "upgraded" to fix this issue in some other way. It's one of those wait and see as more and more current gen RAMs rack up the mileage. But I'll be listening for that Hemi tick each time I cold start my truck, just in case.
My 2004 had no issues between me hypermiling it day-to-day and towing a race car on the weekends. It ticked when it needed an oil change, but it never let me down... and that engine -according to my friends- was supposed to have all the valve springs break, crack the manifolds, shred the lifters, etc. ..and the transmission was supposed to quit long before that. Never happened.
Stay on top of your oil changes with synthetic engine oil, and especially after 16 years of perfecting the Hemi I wouldn't worry one bit.
My 2004 5.7 was a great motor. 330k miles and 15 yrs before I traded it in. I now have a 2017 and at 180k and only 8 years I have the lifter tick. I’ve replaced both manifolds which had sheared bolts and still ticking away. I’ve always been thorough with maintenance so it’s very disappointing to rebuild a motor in a super expensive vehicle after 8 years. This is my 3rd ram and possibly my last if they don’t fix this design.
  • Like
Reactions: RHO
good answer here
