You mean how they should start out? I’m a bit confused.I really feel like thats how they start out. Id like to have 3” more on top of the 3.5”.
No decrease in power, with 3.92's anyway. Probably took a hit in mileage, but I only had 35 miles on it when I installed the liftAny noticeable decrease in power or mileage since the lift?
Yes i meant how they should start out bYou mean how they should start out? I’m a bit confused.
But yes a 6 inch lift would be nice.
I just wasn’t ready to do any cutting or irreversible modifications on a month old truck I’ll wait until my warranty runs out haha
I'm sure Zone will come out with a 1.5" body lift pretty soon. Add that to a 3.5" suspension and you're at 5 inches no cutting and completely reversible. Did the same thing on my last truck to avoid cutting anything for warranty purposes. This was the truck I traded in and it had a 1.5" body and 3.5" suspension. Tires are 33x12.50 ridge grapplers. when I traded it in I pulled everything off and traded it stock since none of the parts are worth anything at trade in.You mean how they should start out? I’m a bit confused.
On the Rough Country 6” the crossmember mount gets cut.There's no cutting to my knowledge on a 6 inch lift it's all bolt up, shocks, springs ect... The 3.5 is nice tho. I like mine. My truck looks Girthy on 35s
All bracket lifts require the front cross member to be cut on 4wd in order to lower the front diffOn the Rough Country 6” the crossmember mount gets cut.
Wanted to post a comparison, let’s see the leveled/lifted trucks
Mine is the silver on the left with 3.5 lift and 285/65/20 ridge grapplers
What 4in kit did you use? Truck looks great!
Its actually 3.5" kit from Rough Country. Measured 4" with a tape.What 4in kit did you use? Truck looks great!
