Leveling Kit
cRam1500
I want to level my 2019 ram 1500 bighorn. I was looking at the motofab 3 inch front and 2 inch rear level. But i have been reading that it can really mess up the cv axles and struts. I would definitely be upgrading the control arms but i don't want to spend the money on cv axle spacers or new struts if its not absolute necessary. I do not offroad at all I am just looking for an improved look. Any recommendations?
Th lift does all or most of the leveling. If you have any rake and want less then you can use the perch on the Bilsteins to finish it off. Generally the struts aren't needed for the level with a lift. They only provide the suspension. So you can pretty much use any shocks you want.
so what you are saying is that i could use the Bilsteins with the zone. what height would i set it at though?
You would get the lift and then see how much rake you have. Then select the appropriate perch setting that you want. If you like the rake after the lift you would use the bottom perch for example. The amount of each setting is in the instructions. If you are paying someone to do the install they will know what to do.
No members online now.
