Leveling kit "North edition"
SkisNH
Hi guys,
I have a 2019 north edition ram and want to add a leveling kit and different tires. My question is...does the fact that the north edition comes with a 1" lift effect what I choose for a leveling kit.
Thanks in advance,
SkisNH
Kinda of, if you had standard suspension, you can do a 2 inch level no problem, most people don’t even have to get it realigned. But now that you have a factory one inch, when doing a 2 inch level, you’re going to have to do upset control arms as well. Because you’re now going to be at 3 in level instead of the two.
Most people go this route:
I just bought it, works great with the ORP.
You should put control arms this way, as well.
Thanks for the link.
Did you end up leveling out your North Edition truck yet? I have one as well and I am searching through the forums and looking for any ideas and advice I can find on what to do. Any real world experience that you can share would be appreciated.
Not yet, the factory lift makes it a more expensive upgrade. It will be done by spring when I do wheels and tires.
Hey guys, any updates on what you used on your North Edition for leveling? I have a 2020 and just looking into it now. Any help would be appreciated.
I have 2019 ORP (factory 1" lift just like the north edition) and installed the Motofab DR-2 (2" spacer) last week. Installation was easy and the kit was inexpensive.
I actually got a little under 2.25" lift in the front after installing the kit and it is almost perfectly level front to back.
I have a 2020 ORP and have been going back and forth about leveling / lifting. Can’t seem to make up my mind. The Ready Lift 3.5” lift is about the same price as the 2” leveling kit. If I choose just to level it for now I have seen a few you tube videos stating if I we level these pickups the upper ball joints will be under too much stress. Anybody have any comments to clear this up or validate their statements?
Thanks
